I am switching to a SWG and I'm struggling to find the best spot for it.
Currently I have an inline chlorine tab feeder that I only use if I'm going to be away for some time.
I know the SWG should be the last thing before the return lines but one thing it's not clear to me yet is if I need some sort of flow valve between the heater and the SWG, I know today there's one before the chlorine feeder.
I think I have a couple options:
- I can remove the chlorine feeder and install it there (but I need to figure out how to remove the feeder while still leaving a couple inches of pipe to install the core55, which seems nontrivial as the feeder is glued to the valve glued to the elbow)
Or Install vertically before the valve and the chlorinator and after the heater (the vertical pipe at the left - weird angle I know)
If I go vertical then I have the perfect space and I would just need to cut and attach the core55 SWG.
Any advice? All I've read is that it can be installed vertically and the installation manual makes no mention of flow valve requirements, so I'm leaning to the second option while leaving the chlorinator empty without removing it.
