- Feb 6, 2015
- 7,834
- Plaster
- CircuPool RJ-45 Plus
Did you add any muriatic acid to lower the pH to 7.2-7.3?
Doing so will help lower your TA as well.
Your TA goal is 60.
When the pH gets to 7.7-7.8, lower the pH again to help lower the TA from 80 to 60.
Don't forget, evaporation is high with our high temps, low humidity and ~40*F day/night temperature swings.
You are adding high TA fill water to make up for the evaporation, which will raise the overall TA of the pool water.
Your TA goal is 60.
