I can't shut it off for a few days. I'd have to turn it on at times to water the gardens and chickens. Would that mess it up much?Shut it off & do the bucket test explained in the article - its only for a few days.
I looked through all my pool paperwork and oddly, pb did not list the auto fill on CAD, bid, no info at all.I have no idea what brand autofill that is. Check your pool paperwork and see if it lists the brand/model number.
The valve to the left of the backflow will shut off water to the copper pipe that goes into the ground to your autofill. What else is hooked to that line?
Can you add a length of hose to the garden hose in the pic to extend your hose reach for the garden and chicken
It doesn’t matter where you set the pool water level so long as the bucket has the same amount of water in it at the beginning of the test. Don’t forget to mark the bucket. You obviously want the water level to be high enough so that you don’t risk the pump sucking air through the duration of the test.I'll check my CYA in 2 days cuz I was just able to check the sock today that it was empty.
today:
fc 15.5
cc .
pH7.5
pool h20 temp 83
csi-0.27
I'll have time for more thorough testing tomorrow.
panel says 3100 salt
I'm a little confused with the instructions on the bucket test. should I fill my pool higher than the middle of the tiles or middle of tiles? then I would put a bucket on the baja and fill it with h20 to the same height of the pthxool h20 and shut off the auto fill?
thx
oops. I misunderstood and thought I should take the rocks out after and then I could see how much h20 was left. I understand some drops will be on my hand and the rocks so that might skew it a bit. however, since it's been almost 24 hours doing it this way how do u think it'd work if I allowed it more time, took out the rocks and then measured the correct way for the next couple of days? Like an ABA test (without the 2d A) and giving less validity to the first A/test with the understanding the drops taken out might have been significant enough to alter the test.The rockswill displace the water in the bucket making the level higher than the pool water. Be sure to scoop some water out of the bucket after the rocks are placed to make them equal
Gene, I didn't test TA the last 2 MA additions because I felt like I've done this long enough to know the TA is not going to get down to where I need it to be from 90 with 2 additions. I had mentioned I'd be very busy these 2 weeks and when that happens my #1 goal ends up being to prevent algae. I get nervous when I skip a day of testing FC and checking the panel but the FC was 14 so I'm keeping it high to at least get that main goal taken care of. I thought I could fit in the bucket homework at the same time. It's ideal to get it done before it gets even hotter. My dad is in town from the East coast and his health is not good so he's my priority above the pool or all else for the next couple days. I'll try to fit in a full test today and at a minimum the basics, but I always feel like the basics r keeping algae out of the pool. That's been my nightmare in the past. I realize that keeping it balanced is ideal but I'm not sure how else to fit it all in somexs. It takes me a while to do a full test. I know I go slow at this, too, with wanting to not overdue chemicals so hopefully it's not frustrating for y'all. I'd like the testing to be reasonable with my schedule. I can't wrap my mind around testing TA that often when it was just 90. Am I missing it? Could it get down to 60 with just 2 MA additions? Thx much.It is important to get your testing done and enter it all in PoolMath.
We need to see a complete set of current test results.
What is the specific reason you added acid when your pH was within range at 7.8
Did you test TA prior to your last two acid adds? If so, what was it? If not, why not?
What is the current CYA?
You added some and it's been dissolved over two days already.
Don't go off into the weeds about a possible leak. Get the pool balanced and then concern yourself with doing the bucket test after that. But also remember to continue testing.
From 90 it could possibly fall to the 70’s or 80’s - as the ta lowers each acid addition will have a bigger impact. Knowing your ta is important when calculating acid for reducing ph so you want to check it & record it every couple rounds before adding more acid.Could it get down to 60 with just 2 MA additions?
that's all helpful, thx.From 90 it could possibly fall to the 70’s or 80’s - as the ta lowers each acid addition will have a bigger impact. Knowing your ta is important when calculating acid for reducing ph so you want to check it & record it every couple rounds before adding more acid.
You’re getting close to your goal so you will need to watch it. Hopefully it is starting to mitigate your ph rise & have a good effect on your csi. You’re doing ok with the fc- you’re correct that adequate fc is paramount.
it’s currently a little high, but aiming for high target is fine
FC/CYA Levels. May can tick the swg back a little notch. The issue with riding above 10ppm is that it skews the ph test which makes your priority #2 (lowering ta) hard to do accurately.
You’re almost done with your initial adjustments after your fresh fill, then you’ll just be on maintenance street. That’s when it’s super important not to get complacent because it can be almost too easy.
Set a schedule that works for you & that you can stick with for doing the full battery of tests weekly then monitor ph & fc every couple days. Around 10-15 minutes once a week & maybe 5 minutes 3 days a week. Probably less if no adjustments are needed. This will ensure you catch back up quickly if something is wrong/askew. For tasks like this I set a reminder in my calendar on my phone or a recurring alarm. I’d forget everything if my phone didn’t remind me!
