Recently we swapped out a pentair LED light in our spa. Another in our pool is burned out (bad seal/water intrusion).
Since then, I’ve noticed the pool and spa lights will turn themselves off without command after 15-45 minutes. I don’t have any egg timers set and they are not on a schedule.
When I reset the breaker for these lights it turns off the entire Easytouch panel. I opened the breaker panel and noticed a blue wire comes off the breaker, routes itself to a gfci plug on the bottom right of the panel as a LINE (tests good, nothing is plugged in), and then comes out as a black HOT and terminates at the transformer (part 521082). One blue LOAD line goes to a relay and the other blue LOAD line goes presumably to the junction box for the lights.
Has anyone had this sort of issue? We did not reconfigure wiring to the breakers when replacing the light, and I tested the breaker by swapping it and seems to be operating normally.
Thanks for any help y’all can toss my way!
