Does anyone know if Aquabright application is effected by the temperature outside? That’s the last step for my pool now and I know we need some days with no rain forecast but wonder about Temp???
The epoxy cure time is temperature dependent and this is the most critical step in the whole process. The temperature should be above 50 degrees and below 90. Humidity can also be a big factor but I would assume your installer should be well versed on the application procedure.
Thanks! I haven’t spoken with the installers myself. My PB is subcontracting it to them.
I remembered seeing something here about temperature parameters, so thanks for the reply! We are waiting now for a rain free forecast.
Why did you stop doing Aquabright? I sure hope I made the right decision with it. I changed from wanting Hydrazzo to Aquabright. It’s now the very last step in my build.
very pretty. I’m thinking I should do that instead of the Mediterranean Blue. The Med Blue is pretty but so much darker. I wish there was an in between.
