G,
Based upon your pics your system can't be doing what you say...
Very odd, it is running the spa speed even though it is obviously not in the spa mode.
If this were my pool, I would use the main panel LCD and confirm that the EasyTouch itself shows the same speeds..
Menu, Settings, IntelliFlo, pump , speeds.. You should see something like 1/8 meaning page one of 8 speeds..
Make sure that the ET only has two speeds and that they are Pool = 1500 and Spa = 2500...
Also check Status..
Jim R.
Also check Status..
Jim R.
