Hello -
My basic question is, can I control my Intellichlor separately with EasyTouch?
Pool build was finished in January and I've been running on the program/schedules they setup basically since then. Essentially they set two schedules - the main schedule they provided was to run on "Pool" mode from 8:00 am to 8:00 pm. The second schedule was setup as a "Cleaner" feature and set to run 8:00 am to 6:00 am. (22hrs). This was intended to be the first 30 days during all the brushing and plaster dust extractions. They told me to just delete the cleaner schedule after 30 days and the 12:00 hour schedule would be fine. I didn't delete the 22 hour schedule but did lower the speed so it was only running on the higher speed for the 12 hours. Now I'm ready to dial in schedule that works for me.
My goals:
Am I thinking about this correctly? Is there a better way to get to my goals? EasyTouch/ScreenLogic is clunky IMO, and I'm not happy that my PB didn't offer or Intellicenter as an option.
Thanks for reading.
My goals:
- I'm trying to figure out if there is a way to control the SWG on a schedule? Perhaps by associating it with a feature? My thinking is to run the SWG for XX hours per day at 100% to meet my demand and turn it off during the remainder of the circulate and cleaning cycles.
- I want to run on low speed most of the time to conserve energy but get the needed filtration. For instance 25GPM for 24 hours would turn over my pool 1.3 times. I also want to "overlay" two or three "skimmer" speed schedules. I have a lot of trees around and want to push up the speed to get better skimmer action. Probably for 60 or 90 minutes mid day and in the evening when the wind settles down. I have a robot so I'm not running a pressure/suction cleaner.
Thanks for reading.
