jesseheyder
4
Tampa, FL
Can anyone explain why when I click “all on” under the lights section, my spa turns on? I recently had 2/5 globrites stop working and coincidentally it was after the PB came to check on a warranty issue. I’m wondering if a setting or circuit was changed while he was goofing off inside the easytouch panel
Thanks in advance
Welcome to TFP.
Go through each of your circuits and check the Circuit Type.
Do you have Screenlogic on a PC?
Reactions: jesseheyder
Jesse,
Do you have SLConfig on your phone?
If so, look under Circuits and use the little down arrow to find the Spa Circuit. Then see If the Circuit Function is set to Spa, like it should be, or something else.
If the Circuit Function is set to Spa like it should be, then look at each Light Circuit and see of any of them have a Circuit function of Spa (Which it should not..)
Jim R.
Thanks for the help everyone. I found the issue. I put on my goggles and noticed that the 2 in question are filled with water. A third just went bad and don’t ya know, it’s filled with water also. I filed a warranty claim and they’re coming tomorrow to replace. I thought it was strange that the spa and pool light went bad at seemingly the same time….
Yellow went bad together and the blue just went bad 2 days ago.
