Factory reset did nothing. On the outside easy touch panel I have 3 choices for pump type VS, VF, VSF. I had been using the VSF, tried the VS, no luck. Getting stuck for ideas..Jeff,
Sounds like a plan to me..
When you set up the pump as VSF, did you do it via ScreenLogic, or via the little 3" LCD??
I ask this because ScreenLogic will allow you to enter a million programs, but the EasyTouch can only use 12 of them.. So maybe, ScreenLogic will allow you to enter VSF while the EasyTouch upgrade will only allow you to use VS???
Give it a shot and see what happens,
