Hello, yesterday I started getting an E05 error on my Pentair master temp 400 HD. I opened the heater up and put a multimeter across the flue temperature sensor and I got 3.8 ohms. So I’m assuming that the temperature sensor is OK.
The air intake is also fine and from what I can tell the water flow into and out of the heater is unchanged.
The heater will run for about 30 seconds to a minute and then shut off, which time the error message shows in the service here light comes on.
Should I just replace the temperature sensor anyway, as this seems to be the most common cause of this problem? I am just hesitant to do so since the multi meter is not reading zero ohms.
I did press the pool button and hold it while the heater was running and it just said 40. Yesterday when I pressed it there was actually a temperature reading of about 250°.
It’s a full week until someone can come out and look at my heater, which means I may not have a heater for the Fourth of July weekend. I would appreciate any help help you can provide. Thanks!
