Sooooo .... when i was closing i had trouble getting one of the directional eyelets (or whatever the correct term is) out of the return and i ended up taking the faceplate off for some reason and never put it back on. Over the winter the liner moved about a quarter of an inch and now i can't get it back over the return to put everything back together.
My thought was to buy a liner sample and patch / cover the entire area, cut out a hole for the return then put the gasket and plate in place and screw it all back together. I'm not too far from needing a liner but want to get another year or two.
Sound ok?
Any other suggestions? I thought of lowering the water down below the return then trying hot water on it to see if it would move enough to go back into place?
Thanks in advance!
Sound ok?
Thanks in advance!
