Drop in steps used outside the pool
So there are trade-offs, for sure.
3 intex pools later, the kids may be gone and the pool no longer needed and the regular steps may still be going strong. A forever stair is not necessarily needed here, although it very may well be preferred anyway by some. (y)
I will likely be the lone vote against composite at the pool here, but consider this. There are several brands which respond differently, but the one I picked from HD for my front deck/steps was particularly slippery when wet. One time while awaiting the school bus before field day, the kids used spray sunblock on it and it was slippery for quite some time. It was also much hotter in the sun than the previous stained deck. Uncomfortable to sit on (with shorts/ exposed skin) or use barefoot. With both water and sunblock coming off everyone getting out of the pool, in bare feet, stained wood may be a better choice and will still outlive a couple intex pools.
I'd think glued treads are a must for slip prevention no matter the material
The problem I've found is with the sandwiches. My nickname for the contact between building materials. Like doubled-up joists. Or treads where they attach to stringers. Or deck boards where they touch the joists. Etc. Any place that water can squeeze into but not so easily drain or evaporate out of. That's the deck/stairway killer. That's where the rot starts, then spreads like a cancer. And unfortunately there's no way to reseal those areas, even if you took the time to seal them all before you assembled them together. So over the years I've successfully combatted this problem in several ways:
- Composite decking
- Pressure-treated ground-contact framing (not all PT is ground-contact rated)
- Liberal and multi-coat application of sealer (like Copper Green) on any fresh-cut surfaces (like the ends of the boards or the cuts in a stringer)
- Careful attention to any areas that can trap water, and designing them out as much as possible (spots where water can't drain away)
- And I've even applied metal flashing to the tops of joists and stringers if the water exposure would be year-round (like under an outside shower, or perhaps some stairs to a pool). I form the flashing like an upside-down U, with the wings slightly spread out like a roof. The theory being the flashing will shed water away from the wood underneath, and only sandwich water between the top of the flashing and the composite material, both of which can handle the retained moisture exposure better than wood, and neither is subject to dry rot.
That might get you 30+ years (climate dependent). Conceivably could double or even triple lifespan over wood only, with none of those tricks and neglected sealing. Ya know, ya get out of it what you put into it.
Anywho, that's how I do it...
I'm tempted to just buy a set of fiberglass stairs or boat dock stairs if I can find them used. $1200 new with railings. Used the price is comparable to cedar lumber for a custom build. Not as pretty but summer is here and I want to use the pool not work on it. Ill also probably move in the next 10 years so temporary is prob the way to go. And they'll be easily resold.
Reactions: Dirk and Newdude
$1200 and you DELIVER ???? My goodness, that's SLENDID Mortimer. Do so post haste. :laughblue:
