Hi all,
I just bought a house with a pool and am having a little difficulty adapting to the new equipment. As far as I can tell the pool does not have an overflow drain. Worse, it doesn't seem to have a spigot to drain the pool. What do you recommend in the short run to drain the pool? What happens if I run the pump and remove the drain plug in the cartridge filter?
In the long run, would you recommend plumbing in a spigot or is there something else you would do?
Thanks in advance!
Thanks in advance!
