Drain pool or chem treat?
qsmith3741
114
New Llano, Louisiana
Side note: which vac head should I be using for vacuuming. The house came with the black one. And these three bolts, I suppose they’re for a diving board? Anyway to figure out which model it fits
Newdude
6,943
NY
When the FC starts to hold, or does hold you officially have the leg up on the algae. It shifts from a chemistry fight, to a filtering fight. It’s no longer growing (or exponentially at least), but it still needs to come out. Getting it out takes time, and drives everybody nuts after having visual progress all but come to a stand still.
Without the feel good progress we lose a lot of fighters. Do not slack or you are right back where you started. Brush and vac with whichever head works best. You’d think that one would be better for all but the 3 heads (you have 2) respond differently for everyone.
This is where the pool owner patience comes in. Babysit the filter and keep that FC on target. The military has surely taught you to hurry up and wait so you are well equipped for the struggle. :ROFLMAO:
Reactions: qsmith3741
qsmith3741
114
So I’ve maintained a FC reading of 20 all day. I added a bit of DE in reference with the forum. The pressure went up to 23 and I’m going to backwash and repeat. Is it safe to add some before night time in case the pressure gets too high over night? I don’t want my filter to explode or anything 🤦🏽‍♂️
mknauss
37,177
Laughlin, NV
Fiberglass
Pentair Intellichlor IC-40
It is best to only add the DE when you can babysit the filter. Backwash when your filter pressure rises by 25% over clean pressure.
qsmith3741
114
Morning check, FC holding at 20. Pool still looks light blue in the shallow end and sea foam green in the deep end. I added some de, brushed. And will check in 45 minutes to backwash and replace de. Guess this is the name of the game for the next few days. On the bright side, I actually can begin to make out my brush at the bottom of the shallow end. Could’ve swore I even caught a glimpse or two of the liner while brushing:)
qsmith3741
114
So normally my psi floats at around 10-12. Today, it’s dropping down to 0 almost and then fluctuating back up. Any idea wha the issue could be? My skimmer flap closest to the filter/pump is always in the up position. Shouldn’t it be down? I’ve never really thought about it until now
mknauss
37,177
Laughlin, NV
Fiberglass
Check the skimmer basket. Sounds like you are not getting any water to the pump.
qsmith3741
114
So the far skimmer baskets is full. It’s the one closest to the pump housing that’s always quick to empty and then it sucks air until it forcefully fills back up.
qsmith3741
114
First one is the skimmer furthest away from pool pump. Second is the one closest to pool pump/deep end skimmer. I popped it down and have ran a water house to it until I figure out the issue so it doesn’t get air in system. So far the psi is normal.
qsmith3741
114
I popped that plate down now the psi is great and it seems to be filtering way more efficiently. The water is actually getting sucked in now. I’m such a noob:laughblue:
  • Haha
Reactions: kimkats
qsmith3741
114
Today’s photos. You can really see the difference between shallow and deep end. You can also see the shadow of a concerned pup who’s trying to push his human into the pool.
qsmith3741
114
I snapped this while vacuuming today. First glimpse of the bottom! Is it normal for the deeper end to take time clearing up/appearing a bit green before the shallow end
Reactions: jseyfert3
Newdude
6,943
NY
Yes the more water you have (deep end) will also have more icky stuff to see through. First you can see the steps, then the shallow end, then the deep end. All going to plan. :)
qsmith3741
114
FC is holding pretty well. I lost about 1 a day now. Attached are updates for today. It’s getting a lot better. It’s hard to see in the pics but, vinyl liner is showing on shallow end. I can see the dip on the deep end
qsmith3741
114
The wait is dreadful. Little itty bitty improvements day by day. About to just throw some algae eaters (the fish) in there with a new cartridge filter:laughblue:
Nickllm
94
Kaplan louisiana
Stay patient, I’m over 2 weeks into mine and i can finally see the light at the end of the tunnel
