Drain Pool for high CH & CYA???
Apr 18, 2017
5
San Antonio
#1
We just started doing our own pool maintenance and had our water tested. Water is clear. How do I drain about 2ft or so from my pool to lower CH & CYA??
FAC 0
TAC 0
CH 650
CYA 100
TA 110
pH 7.6
temp 75
gwegan
2,769
Sacramento, CA
#3
Just a small wading pool I see..
There are several ways to drain.
My equipment pad has a hose bib in the pipe between the pump and filter. I turn on the pump open the valve and pump water to wherever I put the hose.
So first check your pad for something like that.
You can rent a sump or trash pump ( or buy one at Harbor Fright)
If you have fittings in you returns you can make a modified one and attach to a hose
Those all work.
OP
OP
F
Apr 18, 2017
5
San Antonio
#5
Re: Drain Pool for high CH & CYA???
Ok, I do have hose bib in my equipment setup it comes directly off of my filter. WouldThat be the appropriate one for draining the pool? Thank you so much for your help.
Should I be adding any liquid chlorine now or should I wait until I get to CYA and calcium in check?
tim5055
10,096
Franklin, NC
#8
Welcome to TFP!!:handwave:
Not much credence is given to pool store testing around here. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. But, what can you do?? We base our pool care system on accurate testing and only adding what the pool needs, when it needs it. To do that you need your own accurate test kit. Order a TF100 and I also have the SpeedStir and Sample Sizer. They speed testing and accuracy.
