I've seen this question asked before but not about this pump and no definitive answer.
I was wondering if this pump loses prime, will it eventually shut off to prevent damage.
The manual says this under Priming Features - Loss Of Prime :
Notice it doesn't say anything about what happens if it can't ever prime.
But then it says under Priming Features - Max Priming Duration:
"Restart the pump" implies that the pump has shut down. But again nowhere does it state explicitly that if the pump loses prime and cannot regain it after the set time, the pump will shut down and you will have to fix the problem and restart it. That phrase might mean if it can't prime you need to shut off the pump yourself, clear the obstruction and restart the pump.
The reason I ask is I'm having to install a Paramount MV Fuse which is a Safety Vacuum Relief System on my debris canister to make the pool VGB compliant.
Since I have in-floor jets that cause the pressure to fluctuate when it moves between zones, I worry that it will trigger the SVRS which in turn opens the canister to air.
If this happens while I'm away I don't want the pump running dry until I discover the problem.
Default: Enabled
This feature allows the pump to recognize unanticipated low-flow or no-flow situations
while running a program.
For example, the pump will pause for one (1) minute after detecting that it has lost
its prime unexpectedly. After this pause the pump will attempt to prime, and if prime
is successful it will continue programmed operation. If priming is not successful the
pump will continue attempting to prime, per normal priming operation, until a prime is
achieved or priming error occurs and is displayed.
Default: 11 minutes
The maximum priming time can be set from 1 - 30 minutes. This setting is the amount
of time the pump will try to prime before it gives a priming error. If this occurs, fill the
pump basket with water and restart the pump.
