Ok I screwed up. I've been having algae problems for months. We get a lot of leaves and junk blowing into the water, especially in the winter, and although I am good about skimming it out daily with a net I now have a very high phosphate level. Although I have kept my chlorine, pH and alkalinity levels balanced my Taylor test kit does not have a test for phosphates and I didn't take a sample into my local chain pool store because (insert lame excuse here). I had it tested today and the test came out at over 3800 ppb. As a typical chain store they want to sell you as many chemicals as they can and they had 4 chemicals on their list I should use to kill the algae before I even start to treat for the high phosphates.
So my question is do I really need to try and kill the algae before treating (sucking out) the phosphates or can I do the phosphate treatment and then shock the pool to kill the algae? If I should treat for algae prior to the phosphate treatment do you have suggestions as to what to use that doesn't involve 4 different products?
Your expertise and suggestions are much appreciated.
Charles
Charles
