Do I need to bond Intex Pool and White Knight Heat Pump?
Jul 25, 2016
3
Avon, IN
We are installing a 16x36 saltwater Intex XTR Rectangle Pool. We bought a White Knight Heat Pump to go with it because it said that all you have to do it plug it in. However, we noticed in the directions that it needs bonded. If we are using it with the Intex XTR, do we need to bond it? Do we need to bond it to the filter (we are using the Intex Filter)?
That is a removable heat pump on a removable pool. Does not require bonding by code.
That said… If is has a bonding lug I would bond it to the water just in case.
