Each step will have a bead and I am installing a bead track on the bottom face of each step. The steps/bench are not totally done, each will get about 2" of vermiculite. The bead liner will be attached to the blocks, then the vermiculite poured.
Oh we don't even see the mess! We see the fun you and yours will be having in the pool!!! That is some good progress you have going on there.
Do you have your test kit yet? If not NOW is the time to order it as it will not be too much longer before you have water in that bad boy!
Kim![]()
can i ask what the compensation and benefits are for your crew?
SBall, You can and should fill out your signature. You are that close!
-Settings (upper right)
-edit signature (middle left)
Kim![]()
Im not entirely sure I understand what you are asking. The only thing I have not done is the coping, and that was $4k which included styrofoam forms, actually building/forming, laying the rebar, the concrete color, the concrete plus delivery, and the labor to pour, finish, stamp, cleanup, and seal. They are also going to do the vermiculite floor in the next few days, so another $1500.
in the beginning of the OP, i noticed your children were all hanging around the backhoe lol. i considered them your crew since this is all DIY.
