So, I was researching Stenner pumps, which led me down a rabbit hole looking at DIY liquid chlorine pumps. My favorite is still the 110v $25 pump that it looks like several folks have used with success!
I started thinking (sometimes that's bad), I have an old methanol injection system I pulled off my truck. Pump, tubing, controller, tank, etc. The pump is rated at 200 psi, 1 gpm. Surely that's enough power to pump on the pressure side of my system using the commercially available stehner pump port?
Power supply, timer, figure out how to adapt my 3/8 tubing to connect, shouldn't be too difficult, no? I don't know if there's anyone I can really trust to tend to the chlorine when we are away. I will need a larger tank than 1 gal but that should get me started for testing purposes.
I like the simplicity of a low pressure pump and a simple drip line into the skimmer or something, but the way my pool is laid out I can't do that without cooking up some sort of janky looking solution. The line would have to run over the concrete patio around the pool. Es no bueno!
