Discolored pool
Looks like cloudy water (algae). Test strips and improper chemical balancing are the #1 cause. To kill/remove algae, you'll want to follow our SLAM Process, using liquid chlorine at the proper level. Also see FC/CYA Levels. Are you able to order a TF-100 or Taylor K-2006C test kit from your location? That would be ideal.
