Moved from here.
Jim, sorry to jump on an old thread, but figured better than starting a new one. Seems I might be able to only get my hands on a VSF (supply chain issues). Is there a right way to turn of the flow settings? I want to make sure I strictly can operate in speed setting instead.e,
There is nothing wrong with the VSF, it is just that most people do not need the VF portion of the pump. I would buy which ever is cheaper.
If you get the VSF, I suggest that you set up your EasyTouch so that all your speeds are based upon RPM and not GPM..
If the utility is running a rebate, that usually means you must have a professional install. If you planned to do that anyway, then it makes no difference.
Jim R.
