- Apr 26, 2018
- 36
- Plaster
- Pentair Intellichlor IC-40
Not quite. Attach it however you did and there will be a thumbnail at the bottom of the still open post. Click 'insert" on the attachment pic, and then full image and it will post the full picture to the post.Did I post the picture correctly?
Thanks I will remember that for future pics of which there will be many.Not quite. Attach it however you did and there will be a thumbnail at the bottom of the still open post. Click 'insert" on the attachment pic, and then full image and it will post the full picture to the post.![]()
Yes concrete deck will stay. I will keep an eye on that. Thanks.If the existing concrete deck is staying I would keep an eye on the elevation of the pool form to ensure that they are within acceptable finish height of your coping.
Can I attach multiple pics to the same post ? I tried to attach two pics the first time not using your steps and it said files too large. I deleted one pic and it posted. I use my Samsung phone to take the pics. Is there a certain setting I should use to make the posting of pics easier?Not quite. Attach it however you did and there will be a thumbnail at the bottom of the still open post. Click 'insert" on the attachment pic, and then full image and it will post the full picture to the post.![]()
Yes. I think the limit is 10.Can I attach multiple pics to the same post ?
Many phones need to be taken off HDR, or the photos resized.tried to attach two pics the first time not using your steps and it said files too large.
Thanks for the advice. I think these next pics are what you are talking about for the bottom. I do not see any yet for the space between the walls and steel. I will make sure they use them.Good start! Kind of scary I am sure with the loose dirt.
I do have a concern as there are no "chairs" or lifts under the steel on the bottom of the pool. The steel should be raised a bit so it is fully encased by the shell. I also wonder about the amount of space between the walls and steel as they same thing needs to happen there also.
