New fiberglass pool install in Texas
They set the pool into the hole in the ground today. I am not sure if they are finished with the set because I was not able to be there today. There are two places on the pool bottom that are not touching the compacted base underneath. One of them is along an edge and it appears that portion of the side is riding above the compacted grade. This one I am concerned about and will address it in the morning with the installers.
The other is at the deep end but more in the middle. It almost appears as if the fiberglass is warped slightly leaving a void above the compacted stone. Will this void go away as water is put into the pool or should I be concerned?
They should make sure the shell is in contact with the base as much as possible. If there is a problem, now is the time for them to lift, adjust, then validate before the backfill and lock it in.
