:x , so first my water chemistry
Ph: 7.6
Free chlorine 3.5
Combined none
Cya: 40
Alkalinity 80
Current filter : DE using zro cellulose fiber, 48sqft
So i have never had any issues with my pool over the past 3 years, never green, never cloudy,
A month ago i bought an alaklinity increaser from lesliepool to increase alkalinity from 60 to 80, i admit this is probably a coincidence but some white stuff apeared ton top of the water that, never went away. I am putting a link to the photos but if i want to describe it, they are very tiny particles that when grouped together look like mucus, if you try to pick it up with your finger, its almost impossible but when i manage to, immediately disappears if touched. These particles are not found on the bottom as they are very light weight.
Someone told me it might be calcuim as my calcium level is around 600, i bought the stain remover from leslie and 0 difference. Also they are not found on the bottom at all. Also they suddenly showed up one day.
Someone else told me your DE filter is probably torn, i openned the filter and checked all the grids. They all have a very tiny (smaller than pen tip) hole near the top where the mesh connects to the skeleton on the seam lines. But other than that all good,. One more info, i switched from normal DE to zeo cellulose fiber about a year ago.
I am planning on switching to normal DE if that doesn't fix it, change all the grids, if that also doesnt fix it, i really am out of options. Please help
Below are two images.
Ph: 7.6
Free chlorine 3.5
Combined none
Cya: 40
Alkalinity 80
