Deck jet question
Yaeugd
0
Aug 15, 2017
98
Long Island, NY
I just had my pavers installed and had the deck jet hooked up. Every time i use the. I notice a drop in my water level. Is that normal? Or did they make a bad connection? I don’t notice any excessive moisture around the jets or the ground around the jets? Any suggestions?
1/2 inch to 3/4 or a inch . Based on the water line? Had it on for about 3 hours only. Seams excessive. Even for splashing water. I wonder are they connections of the flex hose are supposed to be glued or just stuffed into the hub. Because I don’t remember them using pvc cement
If you lost that amount of water in 3 hours with your sized pool, that is a very large leak. Don't use that deck jet until it is looked at.
