Deck drains
Jimrahbe
25,942
Bedford, TX
K,
I have Deck drains that drain out to the street.. You don't want rain water to run into your pool.. In my case, there is no place for the deck water to go.. Without deck drains the only place water could go is into the pool and then into the house.. :(
They work great for me. The main downside is that the deck has to be slopped toward the drains.. It is not much, and you don't notice it until you try to put a chair or a ladder in the wrong place.. I'd do it again in a heartbeat.
klanel
524
Athens, GA
The contractor says they work great but just wanted to check with others. On other areas of the pool he said we can use the drains or let the water run off down the sides of the retaining walls. The only reason I can think of running down the retaining wall is algae growth. So, I'm debating on that portion.
klanel
524
Athens, GA
I can drain out the back because it's all down hill. But on the back side will be a pool house and don't want the water running towards it. Then on the front side and house side, there will be retention walls with no where for the water to go. Then on another side, it will be open decking and could run off the deck and down the retaining wall.
ajw22
35,166
Northern NJ
Pentair Intellichlor IC-60
Get deck drains where the tops can be removed to clean them out. Builders often use narrow deck drains that cannot be opened and cleaned and they get clogged over time.
