Damp Soil Near Pool Equipment
what does that mean if that's the case?
It's still a leak.
Turning the pump on and off while someone listens closely should help pinpoint the problem.
The sound is usually loudest when the pump is turned on or off.
If you have a stethoscope, you can listen to the pipes better.
You can get a stethoscope at many places for about $10.00.
If you can pressure test the lines with water or air, then the leak can be confirmed and more easily found.
The good news from today. The company redoing the whole pool at the end of January said they would fix that leak (for an extra fee of course). Since they are installing a new skimmer as part of the job their plumbing team is already involved with the project, so they can fix whatever line is the problem. I didn't know they even did this type of work since it's not listed on their site, but apparently they only do it for customers during an actual project (mine is nearly 20K). In a few weeks they will send their team (project begins week of January 23), dig it further out and then fix the issue during the skimmer install.
That ground is really saturated and there are roots everywhere. Are there plants nearby? It must have been leaking for a long time. I know when we dug up our main line we had roots wrapped around the faulty patch (the sewer line runs close to it too). There are two mulberry trees about 30ft away from the area and their roots went straight for the moisture.
I t
There is a pine tree (not from my property) about 20 feet away, but those are not pine tree roots. Pine tree roots are the size of baseball bats. Outside of that, there is nothing around, but I assume there used to be something planted long ago near the heater, which is that area, because we found those sleeves nearby.
I'm actually wrong. There is a tree on the other side of the wall, about 5 feet away.
Not sure what kind of tree this is, Ive seen them often, but I believe this is as big as it gets.
I use this App all the time on my iPhone -
It has been super accurate at detecting all types of plants. And I believe they've expanded it to bugs, pests, plant damage, etc., (in the paid version of course). It helps with making good plant choices too as it gives you plenty of details on water and sun needs as well as temperature zones and pet toxicity.
That's a pretty useful tip.
To find a leak, someone could plant mulberry trees near the suspected leak location and watch which direction the roots go.
Project out the lines in the direction of the roots and use the intersection to find the leak.
Maybe I will patent the idea.
The leak detection should only take 4 or 5 years to complete ...
Reactions: JamesW
I will say this - roots do not cause leaks, they FIND leaks. When people find roots wrapped around a leaky pipe, they incorrectly blame the roots for the leaks. Roots do not have the power to burrow into pipes. But, if a pipe has an existing leak, the roots will grow towards that and may infiltrate a pipe through a leaking joint. Its a common misconception about planting trees close to sewers and pipes - everyone believes that roots will go after them. They won't ... unless there is a leak.
Ah, so the idea is to find the leak by treeangulation.
