Hi,
It's been about a month since I ditched tablets and pool store testing and began my own TFP-style maintenance. I have a few question about FC levels for which I search around and couldn't quite find.
My CYA is 50 (no SWCG, at least yet). According the FC/CYA chart I should be at 6-8 ppm. Let's call it 7. I have been adding 40 oz of 12.5% bleach daily for the past week and my FC readings have been steady at 5.5 ppm. I would like to raise my FC to 7. My daily dosage provides just over 3 ppm of FC. Since my FC levels have been steady, can I assume that my pool is consuming ~ 3 ppm/day?
If so, how do I go about getting the FC level to 7 ppm? Pool math says to add 19 oz of 12.5%, but I'm thinking that's just to get it 7 once, and then it will drop back to 4 after the day's usage. Do I add enough to get to 10 ppm, then revert back to the 40 oz/day to cover the daily usage?
Do the FC levels indicated in the FC/CYA chart represent levels prior to dosing with chlorine, after dosing, or somewhere in between?
Am I overthinking this? (been known to do that
