Hey John. Yes, that is correct. I just bought one myself. Had the worst time trying to figure out how to connect it to the system.
Turns out you have a couple of different options... In the skimmer, if you take out all of the baskets, the pipe at the bottom is threaded. You can get a 1 1/2 inch threaded barb (Looks like this --
https://www.amazon.com/Dixon-Valve-HB150-Polypropylene-Combination/dp/B00DE7YAZC/ref=sr_1_2?ie=UTF8&qid=1505509281&sr=8-2&keywords=1+1%2F2+inch+threaded+barb) that screws into that pipe. There is one just like it that comes with the cyclone. Your vacuum hose attaches one end to the cyclone, the other into the skimmer.
OR
You can remove the pump (I just found out mine isn't bolted to the pad) and go in that way. (This is a little more difficult, but if you are going to take the pump out for the winter anyway, it makes sense.)
OR
You can connect through where your waste line goes out. Remove the waste hose, and hook your pool hose in there. This will ONLY blow out the drain/skimmer lines though.
My plan for this year is to run the water down below the return jets, go in through the skimmer, blow the jets out and cap them.
Then go and hook to the waste line to blow the skimmer and the main drain.
Next year I'm going to remove the pump, but because this is only the second winter, the pool builder suggested leaving the pump connected to make sure that everything settles together to make sure it all fits together. Makes sense to me...
Hope this helps!
-Chris
