You need stabilizer to 30ppm and then will need to SLAM. Once clean and clear you will need to likely raise that CYA a bit higher for the summer months.
If you don’t have a test kit, you’ll be flying blind however. The TF100 or K-2006C are the recommended kits.
Ideally, you wanted your cya at 30 to SLAM but you'll just need to keep chlorine levels a bit higher. Follow SLAM Process and it'll have you lower PH to 7.2 before starting. Don't worry about alkalinity right bow.
