At this point is it necessary to continue to brush daily since I’m out of SLAM?I also decided to test for other levels since FC is under 10. My Ph was about 7.8, Alkalinity was 70, and Calcium Hardness was 75
Cool! Especially not fun at 5:30am before work. Just wasn’t sure if there was a reason to continue because of the metals issue.![]()
Basic Pool Care Schedule
This basic pool care schedule can guide you in creating your own pool care routine. Regular pool maintenance will keep your water sparkling!www.troublefreepool.com
No. Any of the solids (salt, CYA, Ch) stay behind and only water evaporates.Will that sudden temp change against the cooler night temps decrease my CYA?
Exactly why. Cooler nights create a larger delta with the still warm water and more evaporation happens. Then if there's a breeze, the --------------- water becomes rippled ^^^^^^^^^^^^ with more surface area for evaporation/ heat transfer to occur.Also, that’s why each week I have to add 2-3 inches of water because during the week I’ll lose that much water to evaporation.
Was the color any better ?FC was 7.5ppm this morning
Thanks Dave. For now I’m comfortable no leak. I actually went through this last summer with it being my first year with heater. I’ve paid close attention this year so far. When I took cover off about a month ago, I lost nothing over winter. Then continued to see no loss the first couple weeks. The 2 plus weeks since running this heater in this matter is when I’m now seeing these weekly loses. I next expect once we get into consistently warmer weather and my heater usage goes down as well, I should see much less weekly loss, if any at all. Unless of course my wife then tells me she’d like the pool to be 100 degrees.1. The CYA in your pool should remain relatively stable during temperature fluctuations.
2. 2-3" weekly is somewhat excessive just for evaporation. You may have a small leak, I would suggest you perform the Bucket Test.........do you know how?
lol. I hate that this can’t be measured numerically like everything else. I feel like week to week it’s at least a little less green tinted and I’d even say appears to have more blue. As opposed to just a lighter green tint. I anxiously wait for weekends to come to really see the water in different lights. During the week I’m only home before 6:30am and after 6:30pm. No sun in my backyard in the am and very little in the evening. I like being able to see appearance during all times of the day so I can compare apples to apples so to speak.No. Any of the solids (salt, CYA, Ch) stay behind and only water evaporates.
You should see it fluctuate every block of temp swing. For example, we had 3 cool nights in a row and you should have seen a little more than normal loss. Then the next three nights are 70s and there's much less loss.
You'll get a feel for it after a while but if you question it at any point, try the bucket test Dave mentioned above.
Exactly, and hasn’t been any rain really this past week. I think light showers one night.More often than not it all balances itself out here. The big storm that hits on a rando Wed night puts the 2 inches you lost back. It needs to be particularly dry or wet for you to step in.
Of course though. Add some water and it pours 2 days later when no storms were on the radar, or wait it out with the pool a little low because the forecast is terrible for the next week and the storms all blow out to sea and miss us completely.![]()
And...maybe we're back to capturing the last little bits of dead algae floating around, if you are seeing a slow clearing.....as long as your Cl is up enough to not drop too far with no circulation/addition, turning it off and seeing if additional stuff settles out is an easy thing to do...lol. I hate that this can’t be measured numerically like everything else. I feel like week to week it’s at least a little less green tinted and I’d even say appears to have more blue. As opposed to just a lighter green tint. I anxiously wait for weekends to come to really see the water in different lights. During the week I’m only home before 6:30am and after 6:30pm. No sun in my backyard in the am and very little in the evening. I like being able to see appearance during all times of the day so I can compare apples to apples so to speak.
We sure could use a win right about now.And...maybe we're back to capturing the last little bits of dead algae floating around,
Not sure what this means...This is probably where I want to be I think?
my CYA was not holding my FC. I was losing a lot each day. I raised my CYA earlier this week and last couple days seems to have settled at just under 3ppm lose or day.Not sure what this means...
To what? I cannot see your logs. Enable sharing logs with TFP...I raised my CYA earlier this week
Much better.This is probably where I want to be I think?
Yes still tinted. When you say “ tell them I’m questioning my metals and the tint cleared for now”, what do you mean by “and the tint cleared for now”?Much better.
Have some weekend missions for you if the tint is still evident. Go tell the pool store that you're questioning your metals content and the tint cleared for now. Have them test the pool and tap water to see how they compare. If both are high for either choice, then draining and putting it right back in isn't going to help.
Again, ignore anything they push or whatever gibberish they spout. Smile and be polite, decent human rules still apply.
It's easy when they only find one or two things wrong because 'as luck would have it, I have 2 bags of XYZ at home. THANKS 16 year old kid !!!!" (Wink wink). They will find your TA low, they use a different calc and then try to boost it because it's low. On top of that, their target is too high. So either way they'll push TA up.![]()
Also break down the filter and post pics of the carts. Hopefully they have some blue (copper) or brown (iron) to them as another form of identification.
