They did. It's mixed success because some hose water comes out like mud. Yours is much clearer than the terrible areas.Maybe I misunderstood that article I thought the poster used that to filter out the iron when he refilled
Lifted from the article :
Filtering visible iron can be done mechanically. Soluble iron is not so easy and, generally speaking, will pass through any attempts at mechanical filtration.
But also lifted from the article :
Some members have used the Pleatco Spa and Pool Sediment Filter Cartridge connected to a garden hose to filter fill water. Pleatco says the filter has 3 layers and will filter down to 5 microns.[4] Iron needs 3 micron filtering but some member claim it has worked.
So maybe the .5 filters are enough. Again, it's certainly not going to hurt to try given the PITA alternative.
