- Jul 21, 2013
- 65,062
- Plaster
- Pentair Intellichlor IC-60
If you are testing CYA at 90 or higher you should follow step 8 and do the 50% dilution test.
www.troublefreepool.com
If your CYA level is 90 or higher, repeat the test adjusting the procedure as follows:
CYA - Cyanuric Acid Test
Cyanuric acid (CYA) is the chemical name for the product commonly called “pool water stabilizer” … Read more…
- Fill the mixing bottle to the lower mark with pool water.
- Continue filling the mixing bottle to the upper mark with tap water.
- Shake briefly to mix.
- Pour off half of the contents of the mixing bottle, so it is again filled to the lower mark.
- Continue the test normally from step 2, but multiply the final result by two
