- Jun 8, 2024
- 68
- Vinyl
- Autopilot Digital PPC1 (RC-35)
Hello,
I’ve been using my Taylor Pro Salt test kit exclusively for testing my pool water since I got it about a month ago. The CyA test is kind of subjective in the regard that I can make a case that I can see the black dot in the vial at very high levels. My last test I figured my CyA was about 50 so I added 2 lbs of dry stabilizer which should have only raised the level by about 15 according to effects of adding. This was 4 days ago.
I just tested the water again with a generic test strip and the color shows that the CyA is about 150. According to TFP, this is way too high for my salt water pool. Currently my FC is 7. Any ideas on how I should handle? Is there a way to lower CyA if I need to besides removing water?
