We have a pool and the liner was replaced last year. The pool was built sometime in the mid 80s and the sidewalls are definitely plywood, I saw them when the liner pulled away from the coping a bit.
The pool is about 40 ft by 12-14 ft with a 9ft deep end.
Just planning for the future and expenses:
Are there common life times for the walls?
When the walls are gone, is it a 10k fix or a 2-5k fix? Is it fixable at all?
My assumptions are you do it when the liner fails and replace panels as needed, but things aren't always that simple.
Tried searching and couldn't find much.
