Q. And did your plaster survive fine with that method?
A. Well, this is only my 3rd fall/closing with the pool (since 2020). From I can tell and "heard" the pool chemical were VERY poorly managed over the course of the first 11 years of the pool by the previous owner and pool company. (people telling me the pool company would come in, dump 5 gallons of MA, and leave) so after 11 years of what is likely improper care, the plaster was a little rough (not horrible) when I purchased it in late 2020.
-----In 2020, I didn't even know about TFP and let the pool company manage the closing in Fall, they completely drained, winterized, and filled with well water (same process they'd be using for years).... (plaster was 11 yrs old at this time) --
-----In 2021, I learned about TFP and managed chemicals myself through the Summer (staying within the Pool Math ideals), got rid of the old pool company, brought a new one in, and they also completely drained, winterized, and filled with well water (plaster was 12 years old at this time, and fairly rough, but not horrible, no cracks/problems, etc. )
---- In 2022, I had it re-plastered (chip out) because I wanted a smoother surface, and finally opened in August. Since then I've been again managing chemicals (staying within the Pool Math ideals), and am now ready for closing and need to completely drain (as mentioned -- to address some other concerns (not pool water chemical related) that really needs to be done -without- water in the pool.
So wait, you drain for closing, put your well water in the pool for the winter, THEN drain out the well water to open the pool in the Spring, and then refill the pool with trucked in water??? There has to be a better way of managing your water park then that.
Yes, this is what has been done for the last 13 years or so (only 2 previous under my ownership). Drain for closing, winterize, then fill with well water. Then in Spring, drain water, clean, light acid wash, and refill pool with trucked in water. (Note, prior owner in 11 years NEVER filled with truck-water in Spring, he always filled with well water in Spring too, but I decided to truck in water for Spring filling myself). Again, no pool company that has looked at my pool wants to close -without- draining. I've had 4 in total look at it (original pool company, current pool company, and 2 I brought it for pricing/eval).
You are looking for a black or white answer. Water chemistry over a winter in a closed pool is not predictable. I can see the possible problems your well water can create but I can't say definitively if it will happen or not.
Sorry if it seems I'm looking at it as black/white, I'm really not. I do understand there's a lot of variable here and problems that -might- occur as well as might -not- occur, this is why I created the thread and looking for feedback from people's opinions. I'm not sure anyone can say with 100% certainty "This xxxxxx will happen." in my situation, I'm just trying to get input to make the best informed decision. As you can imagine if I really *DO* need to bring my TA down from 300 at closing (even if my CSI is where it needs to be), that is going to be VERY difficult because while I can dump MA into, it usually takes at least 2 weeks of dumping in MA, bringing pH back up, dumping more MA in, bringing up pH, etc. and that's WITH running filter pumps and water features to do it -- I CANNOT do that as easily (lol) if all my pump and water features are winterized already. Hence the big question, if my CSI is okay at closing , am I going to be okay just riding it out through winter? I imagine you can see my dilemma ?
