Newbie pool owner, first post here, had it for about a month. Two days ago one of the hoses popped off the filter and water gushed out. Luckily I spotted the lower water level in the pool and got out to turn off the pump. Unfortunately, what looks like happened is that the water washed out the sand underneath the pool as the filter/pump is right next to this indentation, and caused the vinyl to drop and cause this “crater.” I’m now worried that pressure on this could cause collapse or a hole. I have searched this site and it looks like the only fix is to drain the approximately 15k gallons and shore up the sand underneath and try as best I can to raise the liner, but it will probably never be taught again.
