I think this is the correct forum for this, if not let me know and I’ll fix it.
Last summer I installed a SWG on my return line after my sand filter. The filter and multiport valve are both pretty old (2008) but in perfect working order except apparently the plastic on the output had gotten a little brittle and when I replaced the NPT fitting to the output it cracked slightly. I was able to “fix” it pretty easily so that all I had was a very slight drip and water here is exceedingly cheap and comes almost perfectly balanced right from the tap.
Fast forward to this summer. We had a cold winter and are having an exceedingly hot summer and the thermal expansion on the PVC did it no favors. The leak is quite extreme now and even though the water is cheap, it is a pain to add as much water as I am, salt isn’t as free, and all the leaking salt is starting to bother my yard a bit. I know replacing the multiport is probably the best option, but the way the crack is looks like if I could use the OUTSIDE of the fittings instead of the inside it wouldn’t leak at all due to compression inward instead of outward. The multiport is a 1.5” Jacuzzi brand (dv assy 7-pos 1-1/2NPT TR) and while the inside fittings seem standard the outside fitting doesn’t seem as standard. Any advice on why part I should be looking for to utilize the outside of this fitting or if I should just abandon the idea and replace the MPV?
