Hello. I found a crack in one of the screw holes in my Jandy valve. I posted three photos: the whole equipment setup, a close up on the valve area, and a close close up on the cracked screw hole.
I haven't seen any pump problems yet. The pump seems to work fine, suction and pressure side flow is good, and nothing is leaking. There is always a small amount of air I can release at the filter valve, but this is normal, right? The only other odd this is that my filter seems to run clean at only 2-3 PSI.
I'm new to pool ownership, this came with my house I bought 4 months ago, so I've been trying to educate myself. For a while I didn't know how to use the Jandy valve and had the handle kept too tight while turning it. I don't know how old my equipment is or if the cracks were there before I took over.
Any advice for me? I'm worried that something will go badly eventually with this crack.
