COVID and bleach target
Longbow
3
Windham, Maine
Due to the pandemic, concentrated bleach has become unobtanium around here, so I have had to switch back to 3” tabs. Is my daily goal of 7ppm still the same? Vinyl, pH 7.6, TA 70, CYA 45
TIA,
Jim
  • Haha
Reactions: KC-Newb
mknauss
29,676
Laughlin, NV
Yes. With trichlor, that will be challenge. Plan to drain water when your CYA reaches 60. Drain at least half.
Where are you at? Many members have found liquid chlorine at Home Depot, Walmart, Lowes, Farm Stores, etc.
Richard320
23,612
San Dimas, CA (LA County)
Your target remains the same only for a few days longer. You're adding CYA with every puck you feed your pool. So as the CYA climbs, so does minimum FC. The FC will dissipate, the CYA will remain. You're going to end up in a vicious downward spiral that will end with a green pool and no option but to replace a bunch of water. What do your test results look like? Maybe Cal-hypo is an option?
Longbow
3
Windham, Maine
We’re in Windham, Maine... checking Wallyworld, Lowe’s and HD every couple of days to get back to liquid chlorine. Thanks
