So I have everything plumbed in and just need to run the electrical from my Intermatic to the SWG control panel.
Electrical is not my thing. Im not sure what is my thing, but electrical is definitely NOT my thing.
Ive taken a pic of the Intermatic box, and I think its fairly straight forward. The Intermatic timer box is wired to my breaker box and the breaker box has two 30amp breakers assigned. I guess one for the pool motor and one for the pool light?
Outside in addition to the pool motor (the motor is a Sta-Rite 1 1/2 horse non-variable speed wired 115V 60Hz) I have a 120V wall plug/motor on/off switch.
So heres a pic
[/url][/IMG]
Im not sure (dont know really) why there are two line/load configurations. My pool pump most definitely runs or doesnt according to the Intermatic timer but what else is wired to come on and off from the Intermatic timer is a mystery to me. I only have one pool pump, I dont have a separate pump for the pool sweep
I would think this is fairly straight forward. Ive tested the voltage at (counting from left where wires are attached #1 Line, #2 Load, #3 Line, #4 Load) and with the timer off #1 Line shows 120V and #3 Line shows 120V, while both Load leads show no current. With the timer running there is a current at #1, #2, #3, and #4 (as it should be)
So I suppose connect the Circupool (I have already changed the jumpers in the Circupool to make it 120V compatible) to one or the other Line/Load pairs and see that it works in concert with the pump?
Any help is appreciated. I dont know what I'd do without this forum and the help of kind strangers!
So heres a pic
