Copper Sulfate Crystals
If your CYA is truly 140 (you won't really know until you test yourself with the TF-Pro you are ordering), you need to lower the CYA by drain/refill or a no drain water exchange.
The only chemicals you need are liquid chlorine and muriatic acid.
Return everything else.
While waiting for your TF-Pro to arrive, add 3-5 ppm of liquid chlorine daily.
Use PoolMath Effects of Adding to determine the dose to increase FC.
I just downloaded Pool Math app and WOW IT'S SO COOL!!!! This will help me tremendously by knowing what to add!
Yes can't wait to get that test kit. I already have 1 Gallon of Muriadic Acid... my pH was 7.7 yesterday afternoon. Will get at least pool tests at the pool store until I get my kit. Oh and my phosphates were 184 yesterday at noon so I added some Super Phosphate Remover last night.
What's a No Drain Water Exchange?
I would suspend the addition of pool store potions. Phosphates are not an issue. Here is what to add and what not to add.
Reactions: LaMraVrga
Do NOT add anything except liquid chlorine and muriatic acid.
Only add acid if pH get to 8.0 - and then only to lower pH to about 7.6
Search is your friend.
Which one? Which one would you pick? Not for pool contractors just for a homeowner
You did good. I broke down the deets below. Please read this post and the next post:
