The title is pretty self-explanatory here. I had my water tested at Leslie’s at my copper is at 1.6, which even TFP says is too high. The article I read said that the only way to remove copper permanently is to drain and refill, but I also have a well and I’m worried that is contributing to the copper levels. Leslie’s recommendation is either drain and refill or a “no metal” chemical.
Does the “no metal” actually work to reduce levels? Should I just bite the bullet and drain/ refill?
