Has anyone ever converted an AquaTrol RJ (Return Jet) to an HP (Hose Pipe)?
I read online that Hayward sells conversion kits which I can’t find, I also read you can add a flow sensor but the diagnostics on the board show it is programmed as an AL-7 (RJ) and there is no way to change it to an AL-6 (STD). I’d imagine it would just ignore the flow switch creating a safety issue.
This makes me think I’m out of luck. I’m trying to avoid the cord running across the lawn from the pool to the equipment pad which the HP model would do.
Any thoughts?
Any thoughts?
