- Mar 21, 2018
- 42
- Vinyl
- Hayward Aqua Rite Pro (T-15)
I'm hoping to only break the filter down once at the end when I completely replace the sand.
Sand from deep clean. Not a lot of big clumping. Just a little clumping that is too heavy to be lifted out with the water. I had to feel around and pull those pieces outThe only problem is, and this is very much an unknown in the Baquacil conversion process, is that a sand filter can potentially hold an enormous amount of oxidized baqua-goop. We often see conversions that linger on and on and on with clear water but elevated CCs and an OCLT above 1ppm. This is where the frustration phase comes in because the filter sand hasn't been changed yet and there's likely a lot of trapped gunk in the filter. Backwashing is not powerful enough to remove it and, if the sand is channeled from all the gunk holding it together, you'd never know that the filter is the problem.
Opening up the sand filter to deep clean it gives an indication of what's trapped inside it. You're not removing the sand per se, just sticking a garden hose into the sand bed (carefully) to see what comes up. Knowing if there are any decomposing solids in the filter could potentially avoid another costly drain because, if you drain the pool but don't rectify the filter, you'll be right back where you started. My suggestion to deep clean the filter was to get a bird's eye view of what's in there.
This is all entirely up to you. If it's just becoming frustrating and expensive, then you should simply drain the pool, refill with fresh water and change out the filter sand (and clean the filter out really well) then deal with a possible elevated chlorine loss during the season. Pools normally loss about 2-4ppm FC per day but if your partial drain leaves some residual baqua product behind, you can expect that FC loss to be higher.
At this point, flocculation will not do anything for you. Flocculation removes fine particulates and your water is clear by all accounts. Flocculants also require fairly specific pH and hardness levels so trying to execute a flocc when the water is still so far out of balance is really not a good idea.
Update after filter deep clean and another partial drain and replaceLooks like cream-of-wheat
Flushing out anything that is not sand along with breaking up big clumps will help. Some people use a wooden spoon to gently break up big chunks very carefully so as to not damage the laterals.
Morning readingHey, I know that color!!!
In the morning (or tonight if you wish) can you do a full set of tests and post them here. Please include
pH
TA
CYA
FC
CC
From there we'll see what's our next step. Congrats on blue......I feel something awesome is in your near future!!
Last night I started at FC 25Those numbers look awesome! Let’s let things sit for now and I’ll checkup with you this afternoon to figure out our next action. For now, enjoy a beverage and do some reading. You may want to brush up on the Overnight Chlorine Loss Test as I suspect it’ll be in your best interest to do one tonight.
That is probably not the most accurate reading since the night reading was taken while I was still filling the pool. I added about an inch of water between readings.That pool is looking awesome!
Losing only 1.5ppm of FC overnight is very encouraging.
Great job so far!!
I plan to get a good oclt tonight.
Thanks to everyone for the advise and help. I was on the ledge a couple of times.
Night FC 22.5 CC 1.0 PH 7.5
Morning FC 21.0 CC 0.5 PH 7.5
Looks like I'm close!
Happy Easter!
I didn't add any chlorine last night. It's still coming down from when I set it at 30 to see how much biguanide was left in the pool.Save your pH reagent, with your FC above 10 the pH is not accurate.
Also, why did you dose so far above 15ppm?
You are definitely close, keep at it!
Happy Easter!
