jagger2005
FYI, not sure of all Aqua Rite are the same, but my salt test strips have my salt at 3600 today and aqua rite display is 4200. It still runs without issue. I can only slightly taste the salt in the water
I had 3400ppm but drained some of the pool when I saw an increase of CYA up to around 100 (thanks to AZ Pima Chem). I bought the AquaRite SWG.
Well, either way, my advice remains the same - wait. See if the unit yells at you. It will not damage the cell at all if the salt is a little low.
Yep. That was my mistake. Thought I needed one more bag and 2 days later...NOT. I am too cheap to just dump the water to get closer to 3200
Oh buy it is a hot one out there today. Burned my tootsies on the flagstone. The Aqualink & Aquarite both say the water is 89F; Acurite weather station reports 113F here on dry land. :sunny: Too bad I can't use the laptop in the pool.
I don't plan on adding any more chemicals including salt until I get a handle on FC and CYA. If you think CYA of 85 is okay, I'll even hold off draining more water and hope for rain. https://vimeo.com/135811823?outro=1
- Flappy
Looks like tomorrow is the day for the SWCG unless the pool company comes back again.
FC 11
TC 0
TA 50
PH 7.2
salt: 3000 (k-1766); 2800 (cell)
User manual states that operating levels are 2700ppm-3400ppm with 3200ppm being optimal so I'm going to add a single 40lb bag. At 2800 (cell) Pool Math says I should add 75lbs to reach 3400 but I would rather go easy than risk overdoing it.
Also, I turned down my pump run time. For almost a week I've been running it at 8 hours/day (down from 13.5) and the pool still looks clean.
- Flappy
