so I will sort through later and put a couple more "awesome" ones up tonight
~Yawn~
Fred you’ve picked up your PB’s bad habits. Where’s the pictures you promised us??
The skimmer. Encapsulated in concrete to make it structurally sound.Fred! SWEET! It is DONE! Bet you will sleep a bit better now!
So what is that big hole with the shell around it?
Kim![]()
I am assuming the pool light cord is not in the conduit yet. You should be able to flush water thru the conduit from the pool side to flush it out. Just elevate the other end above the trench a little. Most pool light conduit will have water in it once the pool is full. The conduit will probably be run to an approved pool light junction box which is the required height above the water/pool surface. And then from that junction box back to the panel or light switch. There is usually no reason to try to waterproof the conduit from the pool to the approved junction box.The only concern I have is that it looks like the light leaked from having water in the trench.. Some mud got in. I am sure that there is a way to waterproof it...
They did only bonding and mounting the light fixture box before the pre gunite inspection. I can't tell if the cord is in the conduit or not as both the conduit and the fixture box are taped up on both ends with duct tape. It is possible that the 12v line is in the conduit. I suppose until they are done there are multiple places it can leak. I am not too worried about it at this time...I am assuming the pool light cord is not in the conduit yet.
Unless you have the actual light fixture in the pool or up on the - future - deck area and you can see the cord entering from the pool side light niche, the cord is not in the conduit. The cord is attached to the light fixture in such a way as to make that connection waterproof - and that connection is not field servicable. They will install the light and cord from the pool light niche and pull it back toward the junction box.They did only bonding and mounting the light fixture box before the pre gunite inspection. I can't tell if the cord is in the conduit or not as both the conduit and the fixture box are taped up on both ends with duct tape. It is possible that the 12v line is in the conduit. I suppose until they are done there are multiple places it can leak. I am not too worried about it at this time...
If I said what I am thinking right now I probably would be banned...Its fun to watch the sausage being made... huh?
