I seem to be in loop of a constant battle between PH et AK. For some reason I am having trouble to bring down my ph and have an OK alkaline level. My story goes like this, I go to the store, my AK is low, 0-30ppm and they recommend to bring the AK level above the recommended level. By doing so it raise my ph as the same time, then I have bring down the ph, and it will automatically bring down the AK level at the same time. The problem is that every time I had dry acid or liquid ph down, my ph goes down very slowly while my AK goes down faster. By the time my ph reach an acceptable level, my Ak level is between 0-30ppm, so I have to start the process all over again. It's very frustrating, and when I ask the store guru, he has no answer.
So if you have, any tips I would greatly appreciate.
Eric
Spas: 1500 L/ 400 gallons
Brome
Eric
Brome
