- Oct 8, 2020
- 41
- Vinyl
- Pentair Intellichlor IC-20
Hello all, I finally have our pool refurbished, and now I am dealing with levels. I am hoping someone can educate me. I understand that the ph and alkilinity are connected, and I think I understand that relationship. I have had water in the pool for approximately 3 weeks now with the pump and chlorinator almost constantly on. I take water samples into be tested once a week, (because I don't have any test apparatus...yet). Each time, the ph is slightly high, but the Alkilinity is very high. I put 1/2 gallon of Muriatic acid in the deep end of the pool, in front of the return in the evening the first 2 times I had it tested. That was based on the recommendation at the pool shop. This last time, it had been about 10 days since i last added acid, and the alkilinity level was 280. I was told to either add 2 cups of acid every couple of hours, or add 1/2 gallon that evening, and the other 1/2 gallon in the morning. Is there some reason that it won't come down? Am I doing something incorrect? I have added water twice, maybe 1" or so in level. Any advice is appreciated.
